I heard of lots of people making gamer rigs from this case, and I went through with it and all I have done is been trying to keep this thing from catching on fire with all these cooling solutions.
What I have done as of now
Removed the hard drive cage -
helped cool down my GPU and northbridge by a small margin.
New northbridge cooler with a 80mm fan -
stock heatsink was idling at 80c and loading in the 100cs. Now its wa y better at 56c and loading in the mid 60s
CPU coolers-
Tried both the Noctua C12P and the U9B. The C12P had about 1 cm clearance with the PSU and the PSU fan blowing down directly on the other fan created a terrible airflow.
Now I'm on the N9B which seems to be quite a bit better than the C12P.
I have to keep both panels off to achieve a 55c idle temp and a 70c load. Once the panels come on idling starts at 70 and load in the 90s...
What I have come across is that removing the PSU away from the CPU cooler made a significant difference of about 10-15c once removed and placed outside the case. This helps alot with the northbridge as well that is right under the PSU.
BTW The PSU touches both the C12P and this N9B
Now I have run out of options either get a custom backplate which will run me around $70 to $90 (oh and it seems all the custom backplates files are lost and the only ones I found where for the v350 and I don't know if they have the same dimensions) to just move the PSU position over to the top of the video card potentially going to over heat my GPU instead
or
just move to a new case.
I know theres lots of you with this case. Any pointers on how to handle this? I'm sick of seeing this PC with the panels off, I'm not even going to bother with wire management until I find a good solution because taking this thing apart is a pain in the ass.
CPU coolers-
or
