BrainEater
- Jul 21, 2004
I have a couple questions I'd like to bounce offa Y'all.
I'm working on combining several different projects into a single unit.Here's the deal ;
With my recent upgrade , I managed to get in on the first batch of Matrix Orbital GX Typhoon LCD's...
Awesome display.
Anyways , this display has RGB backlighting that is fully adjustable (255 steps/color).
My intentions are to get that RGB data out of the lcd , either by the serial outputs or by physically 'piggybacking' off the backlights.This will then be used to drive the RGB caselighting I am doing.
It goes one step further ;
I have 45 feet of bookshelf in my computer room , around the perimeter , up by the cieling.I am purchasing 4 wire RGB ropelight to light this shelf and I want to be able to sync it as well.
Here's where the problem , and my questions start.
I am not sure how I'll be getting the RGB data....might be digital might be analog 3-channel .The Display is still basically beta , and the digital baybus has yet to be released.
I also do not know what kind of 'input' the ropelight controller will want.Might be making my own.
Given this lack of data , is there a method that seems like a good route to start preliminary planning with ?
Thanks for any help or insight !
Awesome display.
