IronChefMorimoto
- Apr 14, 2002
I just tried out the Linksys USB 2.0 802.11g adapter I ordered from eBay -- a new-in-the-box WUSB54GP. I wanted to test the unit on my Dell WinXP SP1 (fully updated sans SP2) laptop at work, so I installed the unit and manually added the drivers. I didn't want to use the WLAN utility from Linksys.
The darned thing WILL NOT take a DHCP IP address over a 128-bit enabled D-Link 802.11b access point. A release/renew via IPCONFIG in the command console returns a variety of errors on the renew.
I decided to install the WLAN utility that comes with the unit (v1.05), and I was able to duplicate the signal and connection that I had with the D-Link 802.11b access point. Same problem -- the WLAN utility says that it can connect to the access point but NOT the Internet (a.k.a. it's not getting an IP from the access point's DHCP pool).
Any ideas? Linksys has piddly on its website about this particular unit, and, although I saw some KB articles on the same problem, I've worked through all the possibly solutions.
I should also mention that I will be using this unit primarily at home with a Netgear M314 802.11b router with either 64-bit or 128-bit WEP enabled, so getting it working with a non-Linksys branded access point/router is important. I should also note that this unit is to be used on my Shuttle XPC SK83G.
Thanks, in advance, for any help you guys can offer.
IronChefMorimoto
P.S. - On a side note, this little unit is LITTLE. Tiny -- fits in the palm of my hand without the USB extension cord base attached. It DOES get HOT though.
IronChefMorimoto
