i'd have to agree with that....linspire is a windows wanna-be, linux is not. immitations are almost never as good as the real thing, completely new things [real distrobutions] are very often many times better than the standard [windows].Originally posted by ameoba
you'd be better off downloading a real distro tho...
for the faint-hearted
fedora.redhat.com
mandrakesoft.com
for the ones who want to experience linux a bit more
www.gentoo.org
www.debian.org
www.slackware.org
now there are obviosly many more options, just have a look at www.distrowatch.com
this is true. i guess where my standpoint was coming from is that you can get by without using the command line, they will hold your hand should you need it. meanwhile distrobutions like debian and slackware and especially gentoo leave a lot more of the configuration up to the user and the initial install interface is often a bit less than pretty.Originally posted by Josh_B
I disagree, however, that Mandrake or RedHat lessen the Linux experience. You can still easily manipulate Linux from the command line in either of those, and none of the Linux-power is hidden from the user, it is simply enhanced by a "pretty" interface. I guess you could make the same argument about Linspire as well, but nothing about Linspire really "inspired" me.
Originally posted by Soap
http://belfs.linux-phreak.net/
