I *think* this is a GPU hardware issue, hence my post in the Video Cards forum. I could be wrong though!
I'm currently running a GTX 285 w/ 260.89 WHQL. I recently connected an 1080p HDTV to my PC (via DVI-HDMI adapter) for use as a primary monitor, running alongside my older HP 24" 1920x1200 (straight DVI). Immediately, odd stuff started happening.
So long as I make it through post and initial Windows startup, everything is fine. I can game at high resolution with max settings and all is well. However, more often than not, something odd will happen while I try to bring my rig out of sleep or cold boot:
1. One or both monitor will fail to pick up a signal.
2. The Nvidia drivers will go absolutely bonkers as soon as I enter Windows, spitting out LiveKernalEvent errors.
3. 2D performance goes to hell seemingly at random intervals, causing text to be near impossible to read on both monitors.
When I do eventually get things back up and running, Windows Color Management has lost all of my color profiles and I often have to readjust various settings under Nvidia Control panel.
I've accessed my Event Viewer and the Diagnostics-Performance report is grim. Since I hooked up the LG three days ago and began my dual-monitor journey, there have been dozens of errors and warnings. The majority read:
Boot Performance Monitoring warning.
Shutdown Performance Monitoring warning.
"The desktop Window Manager responsiveness has degraded."
"Graphics subsystem resources are over-utilized.
The vast majority refer to Desktop Windows Manager degradation in one way or another.
It should be noted that I've been dealing with the LiveKernalEvent error since April, but it's been rare. Once a month max. I've seen it SEVENTEEN TIMES since I hooked up the LG, according to Windows Action Center.
Any thoughts? I'm hoping this is a simple matter of replacing the GPU.
