Oct 14, 2009 #1 J Juic3 [H]ard|Gawd Joined Dec 22, 2004 Messages 1,458 Yikes, I put in the line "aaa new-model" and right after that I had a problem with my lan connection now I get a username/password screen from the router, I believe its a 1600 series. Is there anyway to login remotely now?
Oct 14, 2009 #2 S SYN ACK [H]ard|Gawd Joined Jul 11, 2004 Messages 1,243 did you already write the config?
Oct 14, 2009 #3 J Juic3 [H]ard|Gawd Joined Dec 22, 2004 Messages 1,458 I dont remember writing the config.
Oct 14, 2009 #4 G Gott Supreme [H]ardness Joined Feb 28, 2008 Messages 4,958 Juic3 said: I dont remember writing the config. Click to expand... Reboot the router if you didn't wr mem.
Oct 14, 2009 #5 L Lightworker Limp Gawd Joined Jan 12, 2009 Messages 457 Probably not too much you can do remotely, you can break into rommon to boot without a config. Load the old config and fix your authentication. There are a couple extra commands you will need with new model.
Oct 15, 2009 #6 J Juic3 [H]ard|Gawd Joined Dec 22, 2004 Messages 1,458 Yeah, I was about to put in the extra stuff but got cut off . Manual reboot it is then. Thanks.
