jstenuf
- Jun 10, 2002
I have been using a Logitech G9 for over a month and while I like the height, sensitivity display, buttons, software and the weights, I just cant get past the fact that it is too short for my hands.
So I decided to give the Razer Boomslang CE a try and I have been using it for 2 days. It is definitely long enough and wide enough, but it lacks the adjustable weights, sensitivity indicator and the software could use some work. I have the G9 loaded with 28 grams plus the wide grip and my scale shows only an ounce difference between the two, so I do not consider the lack weights an issue. It is to early to tell if there is any difference between the G9 and the Razer during gaming. Anyone have experience with these two mice?
