Well, here I am again. As usual, I'm able to swiftly decide what items I want (for the most part) for an entire computer build EXCEPT for the case. I'm pretty particular about my case in terms of physical appearance. I don't really like too much flashy stuff like windows and excess lights.
The problem is, most cases I'm interested in seem to have too small of a PSU area to comfortably fit the high-end PSUs that I'm looking at. For example, the Corsair 1000HX or PCP&C 1000W. The reason I want such a mammoth PSU is because I want the capability to go SLI 280 GTX down the road. I'll be starting off with these specs initially:
-Core i7 940
-Some form of X58 motherboard (ASUS/Gigabyte/eVGA)
-Some form of GeForce 280 GTX (EVGA SSC edition or BFG OC2 edition)
-6GB Corsair DDR3 1333
-WD Velociraptor 150GB
-Seagate SATA-II 320GB (from pre-existing build)
So I want the extra oomph from my PSU to support a second card for SLI in the future.
Anyway, I'm dealing with the physical limitations of getting a PSU like that into a mid-tower. I'm not all that fond of huge full towers.
Some cases I've looked at:
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112173
GREAT case, but the PSU bay is too small even WITH the extension bracket
http://www.newegg.com/Product/Product.aspx?Item=N82E16811112166&Tpk=V1010B
Might be sufficient PSU space but the huge bar in the middle obstructing you from installing cards unless you slide the mobo tray out is bugging me. That and I worry about the HDs slipping out of the bay when moving the case. I prefer the "locked into place" bays
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119137
Flimsy power button on the side bugs me, also PSU looks like it won't fit since it'll easily run into that fan on the bottom of the case inner-wall
So those are the "types" of cases I'm looking at to give an idea.
Major things I want:
-Space for a 1000HX Corsair or 1000W PCP&C power supply
-Mid-Tower
-Regular ATX, not rATX
-Side-mounted HD bays for easy access/cable management
-A window/lights are fine as long as not done in excess to be flash
I'm having a tough time combining all those aspects together into one single case.
Anyone with a large PSU like that have a mid-tower they can recommend?
-Core i7 940
-Mid-Tower
