So my normal phones are Sennheiser 598s, perfectly fine headphones. Sometimes I like to listen to something with a bunch of bass in it, sometimes maybe a lil of that dubstep. So my thought was that I wanted a second cheap headphone that has a bunch of bass in it.
I was looking at the JVC harx 700, but didn't see a lot of info on how it was on the bass end. I was also looking at the Sony XB500, and since that one got recommended a lot, I decided to just go with that and ordered one.
Well it's going to be going back because it's got a buzz on the left side with certain frequencies. I can play a song and not hear the buzz,and then start another and hear it. I'm just not sure if I want a replacement or a refund. I wasn't crazy about the over-all sound quality, but then I guess that's what I get for trying a bass heavy headphone. How's the harx 700, does that have a little more middle ground in that it's maybe got more bass than the 598, but doesn't totally make everything bassy? I'm basically looking for something in the $30-50ish range. It doesn't matter if it's open or closed, though I would expect closed for the bass.
