Betrayer00GT
- Feb 25, 2007
Hey, all.
This is my first OCed system. I made my first attempt back when the 300a slot Celerons were going to 450 on a regular basis, but mine wouldn’t do it for me. So, here’s my next try. I am looking for assistance in getting to 3.2 on the stock Intel HSF (rest of watercooling still with UPS).
This is what I am running:
E6600
ASUS P5N32-E SLI Plus (the 650i/570 SLI frankenstein model)
Kingston HyperX PC2-8500 512MB x2 (should have a couple 1GB OCZ SLI PC2-8500 modules later today, as well)
Stock Intel HSF cooling (the VGA waterblock is on its way, no watercooling loop again until it shows up next week)
XFX 8800GTS 640MB
I have an image that shows where I am at, but it is almost 500KB in size. I apologize in advance for the size of this image, but I run a 2560X1024 desktop and have nothing to resize images with on this XP install. I will only be running this XP install for less than 24 hours. Just until I can pick up my copy of Vista Home Premium later this morning, when the place that has it now is open.
This image has the Nvidia monitor, CPU-Z, Prime95 for each core, SpeedFan 4.32, and the task manager running with more information than I will be documenting, below:
For those who do not like pretty pictures when words would do (there are more listed voltages in the image, though):
FSB: 333Mhz
Core: 3Ghz
DDR2: PC2-8500 (1066Mhz) at 5-5-5-15-2 @ 2.2v (haven’t tried anything else, yet)
Graphics card OCed to 574Mhz core and 866Mhz (1733 effective) memory
1.3625v CPU (not necessarily as low as possible - Need to find where Prime95 dies to test next step down in vCore for same level of stability)
Each core @ 65C (SpeedFan 4.32) - motherboard reported CPU temp is at 69C
Prime95 has been running on both cores now for an additional hour and a half, or more, since this image. I believe I am at >2.5 hours with it, at the moment.
You know, I would like to see a stable 3.2Ghz, but I have not seen a combination at that speed (so far) which doesn't error out on one of the cores during Prime95 in "0 minutes". I can POST all day long at 3.2Ghz/1138Mhz (PC2-9100) @ a 1.3875 vCore (same timings as above), though. I haven't given up/tried everything, but it may not be doable on this stock Intel HSF.
I probably won't get a chance to try much more on this XP install, as I may have moved on to Vista Home Premium before I get the chance. In all honesty, if this is the wall I hit on stock air cooling, I would be satisfied. Not thrilled, but certainly satisfied. The point of going the OC route was to beat the best (stock) Core2Duo available with an e6600. Big banner: “Mission Accomplished”
So, any obvious pointers anyone can provide on getting to 3.2Ghz on this stock Intel HSF with this system? I would appreciate some things to try in getting that to work. Or, have I really just hit a wall regarding a stable OC point, with this combination of parts and cooling? I would also be interested in guidance on current voltages. I have tried lowering/raising the HT bus and FSB, but have not been able to try all the zillionis of combos for everything yet. Just not enough time. I've only been at this for a few hours. I try to leave things at Auto, if I don't have a decent understanding of where to put them.
So, anything?
[edited to correct vCore number]
E6600
XFX 8800GTS 640MB
FSB: 333Mhz
Core: 3Ghz
So, anything?
