580 isn't worth the cash, buy a 570 instead (and OC it)
6970 isn't worth the cash, buy a 570 instead, $20 cheaper.
6950 is fine as long as you plan to OC it.
Totally depends on the resolution. The 6970 is a great buy at 2560x1440 compared with the the 580 and 570. At 1920x1080 you may as well get a cheaper card.
I have 3 Dell 3007WFP-HC so a max resolution of 7680x1600 but currently only using one and have been since I sold both of my 5870 Sapphire Toxic Vapor-X 2GB cards. I don't game at anything less than 2560x1600
Now that is impressive!Here's a shot of when I had them setup... sorry for the bad photo was a bit messy had to clean it up a bit.
Jayham,
I have a similar setup as yours except with 27" monitors and 5970+5870. I went with 2 GTX 570. Have you had any issues with your Xfire silently disabling? I got so tired with the eyefinity/crossfire drivers that I switched...
I can't find a reason if you are in the high end market to go for a GTX 570 unless you are partial to AMD. The HD6970 is a fine product as well.
I don't know, if you are in my boat and have an mATX set-up with a single PCI-E 16x slot then you would probably want to go for the best graphics card available. I purchased a 5850 last year and regret not stepping up to the 5870 or 5970 since I couldn't crossfire anyway (the MSI 890GXM-G65 PCI-E 16x slots were too close together). That's why it's tough to decide whether or not the 580 is really worth it in my case at $500.
