As title says, looking to order a new build tonight. This is for a friend, he told me to shoot for 600, but 600-700 is fine, the closer to the bottom the better.
Gaming
600-700, tax shipping included
Shiocton, WI
4) What exact parts do you need for that budget?
cpu, gpu, mobo, psu, case, ram, hd
5) If reusing any parts, what parts will you be reusing?
none
6) Will you be overclocking?
Eventually
1920x1080
Tonight
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
No specific features needed.
Windows 7 64 bit.
He was doing it himself at first, asked what I thought of the AMD FX-4170. I told him he should go intel right now, thinking the i5, heres what I put together. If anyone could help save some money that would be great.
i5-3450 Ivy Bridge 3.1GHz - 199
Biostar TZ77XE3 - 109.99
G.Skill Ripjaws 8GB - 46.99
Powercolor 7770 1GHz - 129.99
CORSAIR Enthusiast Series TX650 V2 650W and 1TB HD combo - 169.98
Rosewill mid tower - 39.99
Total with free 3 day shipping 696.93.
I thought may as well try to make him an ivy bridge system to make it last longer, I'm not sure if it can really get much cheaper than this. Otherwise a sandy bridge system I hope would be able to shave some money off. Any input? Thanks in advance guys
Gaming
Shiocton, WI
none
Eventually
1920x1080
Tonight
Windows 7 64 bit.
