Ever since I made the switch from athlon xp to a64 I've had reocurring problems with my internet connection(cable). First problem was internet explorer took over 10 seconds to connect to the internet whenever I started a new window(when you start up it says 'detecting proxy settings' at the bottom for 10 seconds before the page loads) so I switched to firefox. Firefox loads instantly but sometimes while browsing it will just cut out and pages won't load, and my msn will disconnect by itself. Usually to completely get rid of it I have to reboot then I'm okay for a little while. Specs in the sig using XP Home.
