|Leviathan|
- May 30, 2005
Hi,
Yest I installed a new anti virus, and the computer got terribely slow after that i installed it etc apparentely every process that was being executed was scanned before etc ... anyway i decided to un-install it
that done i also installed a couple of games that i saw in the add/remove programs window which i don't play anymore
I *restarted the computer for the changes to take effect*
the comp posted, the windows xp logo loading screen came and than a blank screen
i restarted ... chose the 'previous correct setting mode' and still the same
i restarted ... chose safe mode and a list of 'c:winodw/partition/drivers/xxx.dll' was ouputted on the screen and the log in screen afterwards, if i click on any user or on 'turn off your computer' the computer stops responding
i re-inserted the windows cd and tried to reapir the windows installation on that partition and when it was finally complete and i rebooted, after the windows xp logo loading screen a new screen appears which says approx.:
Can't find DLL files for Windows Kernel
*Now, i installed a new windows installation on another partition just to check if all data is ok, apparently it is except for some pics i had on the desktop [at least those are the ones which i met till now]
now, what should i do? should i try copy these dll files form the new installation to the older one? if yes, how is ist done? + any other suggestions? i would like to spare all that time reinstalling all dirvers, alll rpograms, restting system to my tastes etc
**Note: After a few restarts the checkdisk scan utility appearied check my disks for consistancy and a couple of times it processed all the data i had from mp3/wma and my 7000 Pics directory with the tag - 'retrieving orphaned file *path/name.xxx* '
My partitions are as follows
c: local disk 50gb - old win installation / all program files / documents
d: data drive 100gb - data directory /pics/music
g: game drive 50gb - games folder + new win installation
all drives are in NTFS format
*i have already transferred a backup copy of my profile onto d:
as you cna note, i can't understand why the chkdisk actually scanned d: since it is not related with the operating system
Thanks for reading all this, but i thought it is better if i give detailed information from the beginning.
Thanks in advance for all your help
