I'm kind of window-shopping for a projected build and have been trying to find some quality memory. Mostly I'm looking for high-speed memory with a low profile, preferably 1866 or better as I read somewhere that the new AMD processors will support that. Problem I'm having is that it seems most of the quality memory comes with tall heat sinks and I don't think that'll work with my hsf. So far the closest I've come is this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
But that's new and only rated to 1600, and I really want 1866 as my standard. I figure that I may as well hit the wall from the get-go this time instead of trying to OC. It'll likely go into this board:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
Do you guys know of any good quality low-profile memory that comes rated at 1866? I'm looking for an 8gb kit most likely, unless somehow there is a 16gb kit available.
