Corporal79
- Oct 28, 2004
I'm not a cisco guy by trade but I can't seem to make any headway on an ASA issue I have right now.
throughput is like 1/10 of what it should be. Upload is maxed out around 4mbps, taking the ASA out gives us about 10-14mbps
show interface results...
anything obvious?
Interface Ethernet0/0 "", is up, line protocol is up
Hardware is 88E6095, BW 100 Mbps, DLY 100 usec
Full-Duplex(Full-duplex), 100 Mbps(100 Mbps)
Input flow control is unsupported, output flow control is unsupported
Available but not configured via nameif
MAC address 2894.0f96.b2c6, MTU not set
IP address unassigned
284772 packets input, 279394431 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 pause input, 0 resume input
0 L2 decode drops
277 switch ingress policy drops
268941 packets output, 92565119 bytes, 0 underruns
0 pause output, 0 resume output
0 output errors, 0 collisions, 0 interface resets
0 late collisions, 0 deferred
0 rate limit drops
0 switch egress policy drops
0 input reset drops, 0 output reset drops
Interface Ethernet0/1 "", is up, line protocol is up
Auto-Duplex(Full-duplex), Auto-Speed(100 Mbps)
MAC address 2894.0f96.b2c7, MTU not set
273940 packets input, 94416361 bytes, 0 no buffer
Received 1825 broadcasts, 0 runts, 0 giants
0 L2 decode drops
1557 switch ingress policy drops
283003 packets output, 277824006 bytes, 0 underruns
0 rate limit drops
Interface Ethernet0/2 "", is administratively down, line protocol is down
Auto-Duplex, Auto-Speed
MAC address 2894.0f96.b2c8, MTU not set
0 packets input, 0 bytes, 0 no buffer
0 L2 decode drops
0 switch ingress policy drops
0 packets output, 0 bytes, 0 underruns
0 rate limit drops
Interface Ethernet0/3 "", is administratively down, line protocol is down
MAC address 2894.0f96.b2c9, MTU not set
0 L2 decode drops
0 rate limit drops
Interface Ethernet0/4 "", is administratively down, line protocol is down
MAC address 2894.0f96.b2ca, MTU not set
0 L2 decode drops
0 rate limit drops
Interface Ethernet0/5 "", is administratively down, line protocol is down
MAC address 2894.0f96.b2cb, MTU not set
0 L2 decode drops
0 rate limit drops
Interface Ethernet0/6 "", is administratively down, line protocol is down
MAC address 2894.0f96.b2cc, MTU not set
0 L2 decode drops
0 rate limit drops
Interface Ethernet0/7 "", is up, line protocol is up
MAC address 2894.0f96.b2cd, MTU not set
6304 packets input, 3136838 bytes, 0 no buffer
Received 26 broadcasts, 0 runts, 0 giants
0 L2 decode drops
10324 packets output, 6645748 bytes, 0 underruns
0 rate limit drops
Interface Vlan2 "outside-primary", is up, line protocol is up
Hardware is EtherSVI, BW 100 Mbps, DLY 100 usec
MAC address 2894.0f96.b2ce, MTU 1500
IP address 74.112.39.114, subnet mask 255.255.255.248
Traffic Statistics for "outside-primary":
282041 packets input, 271091540 bytes
266914 packets output, 87132592 bytes
1901 packets dropped
1 minute input rate 671 pkts/sec, 649691 bytes/sec
1 minute output rate 640 pkts/sec, 212357 bytes/sec
1 minute drop rate, 4 pkts/sec
5 minute input rate 714 pkts/sec, 690095 bytes/sec
5 minute output rate 674 pkts/sec, 218277 bytes/sec
5 minute drop rate, 4 pkts/sec
Interface Vlan10 "VLAN_DEV", is up, line protocol is up
IP address 10.10.10.1, subnet mask 255.255.255.0
Traffic Statistics for "VLAN_DEV":
141883 packets input, 21924447 bytes
161702 packets output, 168258117 bytes
1259 packets dropped
1 minute input rate 298 pkts/sec, 45210 bytes/sec
1 minute output rate 342 pkts/sec, 355277 bytes/sec
1 minute drop rate, 2 pkts/sec
5 minute input rate 364 pkts/sec, 55544 bytes/sec
5 minute output rate 416 pkts/sec, 436798 bytes/sec
5 minute drop rate, 3 pkts/sec
Interface Vlan20 "VLAN_PRODUCTION", is up, line protocol is up
IP address 10.10.20.1, subnet mask 255.255.255.0
Traffic Statistics for "VLAN_PRODUCTION":
98401 packets input, 59554286 bytes
86931 packets output, 69349100 bytes
187 packets dropped
1 minute input rate 253 pkts/sec, 147796 bytes/sec
1 minute output rate 225 pkts/sec, 192189 bytes/sec
1 minute drop rate, 0 pkts/sec
5 minute input rate 247 pkts/sec, 149723 bytes/sec
5 minute output rate 220 pkts/sec, 175334 bytes/sec
5 minute drop rate, 0 pkts/sec
Interface Vlan30 "VLAN_WIRELESS", is up, line protocol is up
IP address 10.10.30.1, subnet mask 255.255.255.0
Traffic Statistics for "VLAN_WIRELESS":
29138 packets input, 5698460 bytes
33704 packets output, 32815480 bytes
391 packets dropped
1 minute input rate 96 pkts/sec, 19822 bytes/sec
1 minute output rate 106 pkts/sec, 102911 bytes/sec
1 minute drop rate, 1 pkts/sec
5 minute input rate 66 pkts/sec, 12951 bytes/sec
5 minute output rate 77 pkts/sec, 75296 bytes/sec
Interface Vlan40 "VLAN_GUEST", is up, line protocol is up
IP address 10.10.40.1, subnet mask 255.255.255.0
Traffic Statistics for "VLAN_GUEST":
1830 packets input, 257547 bytes
1656 packets output, 1136676 bytes
28 packets dropped
1 minute input rate 1 pkts/sec, 213 bytes/sec
1 minute output rate 1 pkts/sec, 575 bytes/sec
5 minute input rate 5 pkts/sec, 808 bytes/sec
5 minute output rate 5 pkts/sec, 3668 bytes/sec
Interface Vlan99 "VLAN_MGT", is up, line protocol is up
IP address 10.10.99.1, subnet mask 255.255.255.0
Traffic Statistics for "VLAN_MGT":
0 packets dropped
1 minute input rate 0 pkts/sec, 0 bytes/sec
1 minute output rate 0 pkts/sec, 0 bytes/sec
5 minute input rate 0 pkts/sec, 0 bytes/sec
5 minute output rate 0 pkts/sec, 0 bytes/sec
Management-only interface. Blocked 0 through-the-device packets
anything obvious?
