Yep, I've tried every vcore increment up to 1.4375v and each settings makes a difference in the reported vcore. It's a little undervolted, but each setting does increment it. So, I'm clear of the problem.gazza_new said:I've only tried the board upto 1.37 but every vcore i set works!
btf said:synergyo1 what bios version are you using?
Power supply is an OCZ-520. Other voltages look ok. 11.92 for 12v. 4.98 for 5v. If my memory is accurate.
I think it might not be enough psu for this rig. I seem to have trouble overclocking both the videocards and cpu together. Either O/C by itself is fine.
I got an Antec 430 watt in my closet. I'm thinking of using that to power the mobo and use the ocz-520 for the 7800GTX's.
btf said:I also noticed that whether I set the vcore to 1.55v or 1.50v it is being reported as 1.500/1.520 so this seems to confirm what people are seeing.
I might just switch to a DFI board. I've got the vapochill bug. And this board ain't going to cut it.
