Hi,
I've had a Hauppauge PVR150 MCE edition in my HTPC for a couple months. It's been ok. Actually, I've been pretty unimpressed with the video quality in general. It definitely looks worse than Live TV, but that's a different matter.
I just got a receiver and 5.1 speaker system on the weekend. I've successfully set up SPDIF passthrough on DVDs and AC3 encoded Divx/Xvids. I've just tried watching TV for the first time through the HTPC, and the sound is really low volume. Significantly lower than the rest of the HTPC's sound output. When I turn the volume up, there's a lot of buzzing coming through, like the kind you get when you try to overamplify a crappy sound source. I'm not really sure what the culprit is. Definitely not the receiver or the speakers. It's either the sound card (onboard) or the PVR card.
I didn't have this problem before I had the speakers, but I'm trying to figure out what's changed since then.
In terms of setup, I have a STB accepting coax input from the wall. The STB then has a coax running to the TV (for watching TV without the HTPC), RCA cables running to the PVR card, and finally a digital coaxial cable running to the receiver. I suspected the digital coaxial cable might be the culprit since I added that with the receiver/speakers, but I unplugged it and it didn't make a difference.
The HTPC has a digital optical cable running to the receiver, and an RCA video cable running to the TV.
Does anyone know what could be causing this? I've checked all the connections, nothing seems to be loose. I've tried disabling every setting I put in for SPDIF passthrough, none of them made any difference.
Any ideas would be appreciated.
Thanks,
Adrian
Thanks,
Adrian
