Makave7i Tha Don
- Oct 1, 2004
So I built a new rig with windows 7, I previously had xp. And what I had always done for YEARS was to create my playlists in winamp and save them as m3u's. Then all I had to do was open up itunes, go to import playlist and select it and boom all my songs would pop right up and I could add and sync the playlists on my ipod.
However that does not work anymore for me. I create the playlist the same way as always, and then open up itunes and go to add it and the playlists add to the column on the left, but they are completely blank, no songs come up on the main right side to listen to or play and you can't add them to any ipods. These same playlists all work fine in winamp. So what's the deal here?
