Jim Robbins
- Oct 9, 2006
Hello all!
I just picked up the Magnavox 37MF437B at my local Sam's Club 2 days ago for about $900 plus tax. It's a 37" 1080p tv and I just had to hook it the computer last night. I first tried it with the VGA cable, and it wouldn't let me set it to the max res of 1920x1080. Then, I used an HDMI to DVI adapter/cable and tried it on the HDMI port of the tv. It kindof worked, but the ATI X1950XTX card (on Windows XP) had some scaling option on it, and I couldn't get it to map pixel perfect. For some reason, it was stretching the image an extra 3 pixlels wide and gave a strange pixel effect on text because it was scaling. Anyway, I couldn't get it pixel perfect again...
So, next, I downloaded good ol' PowerStrip, and started playing around. As I messed with timings and widths, it seemed that I could get it to sync perfectly if I ran it a 59hz or 61hz in 1080p (which I am surprised that the screen could even handle that, or even recognize the signal). But then, no games would run. PowerStrip was conflicting the the video card driver some how and the computer would blue screen when bringing up 3D mode.
At some point in the process, I double clicked on the "Screen" icon in the PowerStrip monitor config page, and it removed the resolution and refresh limits for the video card. I think that stuff is stored in the registry somewhere. Anyway, I was ticked that I couldn't get Guild Wars to run pixel perfect, so I turned off PowerStrip so it wouldn't launch on reboot, then I hooked the VGA cable back up and restarted.
Bam! WIth the VGA cable, and no limit on the resolution setting, and PowerStrip NOT running, I was able to get 1920x1080 at 60hz now. And, Guild Wars ran, and it's a beautiful thing!
I have a couple of questions:
1. Anyone else try the 37MF437B as a computer monitor? If so then...
2. Would an NVIDIA card work any better or worse via DVI to HDMI? My laptop has an NVIDIA chipset and a DVI port, I should try it out... Hmmm...
3. Do you think I'll actually need a video card with a real HDMI port to get the sync to work without messing with PowerStrip, etc?
4. Is the TV doing the strange scaling? Or is it the video card? I want to know if my over the air 1080i is just getting line-doubled, or line-doubles and screwed up width wise.
5. Can I get an HDMI device, like HD DVD player or Blu-ray player to map pixel perfect to 1080p? I have a PS3 I can hook up, and a Toshiba HD-A35, but I don't know what content on those devices would even give me a pattern that shows a 1 to 1 pixel mapping for a test...
Any input as I dig in would be much appreciated. Oh, and if you wonder about the Lag? It seems pretty acceptable so far. And, if I can figure out the 1 to 1 pixel thing soon, then I'll hook up my CRT and do some actual testing. I don't want to screw with that if I can't get 1 to 1 working however. Later all!
