honestjohn
- Jul 28, 2004
This is going sound like a dumb question to you guys that have been doing this for years, but I just moved from AGP and built my first PCI-E based rig over the weekend using a E6600/GA-P35C-DS3R Motherboard.
Anyway, the past two days I have been screwing around with some overclocking and was getting concerned about my temps which were 35c idle and 80c after running Orthos for 10 min. using blend or small fft. Same temps even regardless of overclock. I'm currently using the stock heatsink/fan with Zalman Thermal Compound. Had made the decision to pickup the Arctic 7 Freezer Pro and then decided to update my BIOS. I updated from the original F3 BIOS to the F4E Beta and my temps are now reading 33 idle and only 56c under full load overclocked to 3.0 Ghz. in Orthos and I'm now up to 40 min. I know they aren't the best temps. But why the big drop in temps aft6er the BIOS Flash.
Please be gentle. For the past several years I have been using AMD CPU's and motherboards which were not overclocker friendly and my last Intel Processor was a Pentium 133 Mhz. No shit.
