Originally posted by ZenPirate
Out of those two.. Suse.
personal opinion, Fedora Core 1
Of the two, yes.Originally posted by Zwitterion
I would almost go as far to say as Mandrake is the easiest distro. That may be what you're looking for. If you really wanna learn how to use linux, try a compiled-distrobution.
Well, I can tell you that my 9600pro works...sorta (under fedora )Originally posted by Shorty
Mandrake will not work with my Radeon 9800 Pro... and believe me, I've learned alot of different commands in the console just because of the damn problem! I think I'm going to try out Fedora now, or download the soon to die Red Hat just for simplicity.
Originally posted by XOR != OR
I get opengl running, but I can not get everquest to run under winex. Well, it runs...unaccelerated.
Fedora would not work... I'd download a copy, check it against the md5 or whatever file, everythings ok... burn it, start it up... FAIL. At least four times on four different CDs, each from different websites and burned at different speeds. I redid Mandrake and this time had the VESA (or whatever) drivers load... it worked! I'm using Mandrake right now...
This sounds like a CDROM compatibility problem. I've run into this quite a bit with redhat distros, and I have yet to figure out the problem exactly.Originally posted by Shorty
