To make a long story short my WD2000JB has massive cluster damage. It ran perfectly fine then one day it just refused to boot. I managed to re-install windows xp but it refused to boot again just 24hours later and I was not even able to re-install windows at all this time. After installing windows xp on a 30gig maxtor and setting it as master, I ran chkdsk on the WD drive with the /f and /r switches. At one point I noticed it was writing 6.5 million bad clusters to file. ouch!
My main priority is salvaging the data on the drive. At first I thought that chkdsk restored the files but upon further inspection some are listed as 0kb while others will show as being 100mb for example but when in reality only take up 15 mb on disk making the file useless. By mistake I ran the chkdsk on windows pre SP1 forgetting that it couldn't read more than 137gb. I wonder if that had any effect on the recovered files. The drive is not clicking and it passes speedfan's smart test with a rating of 94%. Also according to windows it is running at UDMA5.
So my options from what I've read are to try and repair the drive itself using either spinrite or HDD regenerator. Or trying to manually recover the data using Getdataback, etc...If I try to repair the drive using spinrite, will it in any way lessen my chances of recovering the files using getdataback? Basically I need to know ASAP if I should go out and buy another drive to attempt data recovery or try to get this drive working again. What are the chances? Please advise, I really don't want to do the wrong thing.
Random questions:
1)Aside from SATA drives being cheaper and having a thinner cable aiding in better airflow, are there any other advatages in picking up a sata drive over a pata?
2)In speedfan 4.32 I am getting a temperature reading of 127 degrees for temp3!! Is that for real? Which peripheral is that?
3)In windows xp, one of the partitions on the WD drive has the files and directories listed in blue. What does that signify?
Random questions:
