fibroptikl
- Mar 9, 2000
I'm trying to create a RAID0 using 3 RAID6's that are created on 3Ware 9650SE-8LPML in Fedora 8 x64.
I go to create the /dev/md0 using the 3 RAID6's and I use the following command:
mdadm --create /dev/md0 --level=0 --raid-devices=3 /dev/sdc /dev/sdd /dev/sde
But get the following output:
mdadm: Cannot open /dev/sdd: Device or resource busy
mdadm: Cannot open /dev/sde: Device or resource busy
mdadm: create aborted
[root@localhost ~]#
What's going on? I've ran 'lsof | grep sdd' and 'lsof | grep sde' and nothing has hold of it.
I tried to erase the superblock on it using:
mdadm --zero-superblock /dev/sdd (or /dev/sde) and I get:
mdadm: Couldn't open /dev/sdd for write - not zeroing
What's going on here? I used to be able to do this with 2 devices fine, except now when I try 3 I get the above errors.
[root@localhost ~]#
