I recently got a Tapwave Zodiac 2 retail demo unit, and I've been hacking around with it. The unit plugs into AC adapter without needing batteries, which could come in handy as a regular Zodiacs are nearing their end-of-life on the Li-Ion cells. I didn't look at the adapter closly enough, and thought it was DC. Which would make sense, as it plugged directly into the battery harness, but it turns out that it was AC. Since I needed to know what poliarity it was, I was trying to measure DC Volts on the power supply. All I got was zero... Figuring it might need load to work, and fearing that I had somehow killed the power supply, I plugged it into the unit, the unit fired up just fine. I moved to the rear of the molex on the device side, where there was far less chance of touching the probes together, and put the probes in. As soon as both were touching the metal, the unit shuts off! I immediately remove the probes, and the unit turns back on.
However, now it can't find files on the SD card! IT gets worse, as I pull the power supply, wait a few seconds, and try again, now it can't find the signature for an app in flash rom!
What the heck could've happened? The probes did not short together, and I don't see any signs of shorting on the cable itself. Not only that, how could the unit itself have been damaged instead of the power supply? Is measuring AC with a cheapy DMM set to DCV really that dangerous?
