upriverpaddler
- Jun 11, 2004
I just got my first HDTV with my tax return. I could have afforded bigger, but a 37" was the biggest I could fit in my TV cabinet (which I like enough to make the sacrifice). I've got about 3/8ths of an inch gap on either side.
My plan was to use my everyday PC and buy a Media Center case. Has to be ATX. But now my TV cabinet is forcing me into another sacrifice. The hole for the case is only 5 5/8ths inches high. Sigh. I think I was pretty thorough in my search for a case but all I came up with is an nMEDIA 500BA. It has no reviews on newegg.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811204023
Does anybody have a recommendation for another case? Will there be a problem installing regular PCI cards in a case this high?
P.S. I've hooked up my PC to it. 6600GTOC DVI out to DVI in on the 37w3 and I am thrilled with the way it looks. And I'm so happy to be able to finally put my Logitech Surfman to good use.
