Chowder Head
- Oct 20, 2005
Okay, so I'm planning on going with a 2GB (1GBx2) to go along with my MSI Diamond Plus mobo. The mobo itself supports DDR 266/33/400. The 400 would be the best to go with, correct?
Hopefully so because here we go. Now I've been looing at this Corsair XMS becuase it seems like a pretty good price at $140 after MIR. Now the first question would be what's the difference between these two?
First: http://www.newegg.com/Product/Product.asp?Item=N82E16820145486
Second: http://www.newegg.com/Product/Product.asp?Item=N82E16820145491
Also, I've been searching the memory forums and what has been recommended to others, especially by eclipse, is the G.skill. I don't know which one of these would be suit me well, if I were to go with the G.skill brand.
First: http://newegg.com/Product/Product.asp?Item=N82E16820231047
Second: http://www.newegg.com/Product/Product.asp?Item=N82E16820231032
Lastly, which would YOU recommend to me? I plan to overclock it but I want stability first. I'm a total n00b when it comes to overclock but I'd like something I can learn on and improbve.
And if someone can convice me the more expensive G.skill is worth it, I'll go with that. But the sooner I get help the better because the MIR for the Corsair ends TODAY.
FWIW, sorry for amount of posts I've made in the forum.
Any help is greatly appreciated, thanks!
