If memtest shows errors at high speeds around the maximum the RAM is rated for, but is fine at 'normal' speeds (1333-1600) does that suggest that the RAM is definitely faulty at its' rated speed? or does it suggest that the OC is too high for the CPU's memory controller?
How would you prove that the memory is faulty, rather than the CPU just isn't able to cope with the OC?
