-=Antimatter=-
- Feb 8, 2005
That's probably so that you cannot price match it at other stores, thus keeping this pricing only at MC.I never get why MC advertises the CPUs at full price then puts the in store discount in tiny print under the deal. Most people looking at the ads never even realize you can get it for 200. Or the great deals they have on lots of CPUs.
I wouldnt pay $150 for one of these.
...wait... WHAT?
Two things, one this has been going for $200 for a while now, this is a repost.
Two, the 950s suck compaired to 920s. Intel is just trying to clear stock by marking them with a higher number, even though quality seems to have went down. The 920s clocked way higher. My friend just tried this "deal" and it took 1.4v+ to get 4.2 stable without HTT on, and would not be stable at all over 4 with HTT on. He sold it on ebay and grabbed a W3520.
I wouldnt pay $150 for one of these. 920 C0s clock better.
not true at all - the 950's clock higher and use far less voltage.
If you look around, just about everyone is complaining about them since they dont clock nearly as well as 920s.
because most people don't know how to over clock a 930 or 950 - first thing you need to determine is how low the voltage you can run it on stock rather than the usual "lets see how much I can bump up the qpi."
check out legit reviewers of it and you'll see what it can actually do - and I have one running 4.0 at 1.2 volts and I can push it much higher but I prefer it to be cooler.
There is like near zero real world difference between a 4.4Ghz and 4.2 Ghz i7 for almost anything. You're already faster than the fastest stock clocked chips at that point, you really gonna throw that big of a hissy cow (NOT FOR $150 L0L0L0L0L) over that?If Im going to shell out the money for another i7 build, Im not going to spend $220 on a chip that cant do 4.2HT. Id rather spend $250 on ebay for a good batch 920/w3520 that will do 4.4HT.
This makes no sence at all, and lol at looking at a review site for OCing potential.because most people don't know how to over clock a 930 or 950 - first thing you need to determine is how low the voltage you can run it on stock rather than the usual "lets see how much I can bump up the qpi."
Hell I like AMD better right now for value even I have to admit this is a great deal.
Also, the only real point to an i7 build is benchmarking, other wise you get more daily bang for buck from AMD or 1156.
Ive had 7 builds with i7, I personally wont go back to it again unless its a 3849 batch 920/w3520. They have no trouble running 4.4HT daily stable around 1.3v. Also, the only real point to an i7 build is benchmarking, other wise you get more daily bang for buck from AMD or 1156.
The average 920 will do 4.2HT, the average 950 has trouble doing 4HT. Point is, find a used 920 if you want more bang for your buck. Very easy to find them cheaper then $220.
Fuck this in-store bullshit. I don't even have Fry's in Florida.
Its microcenter...
lol srsly if you think the average 920 runs 4.2 ht on - on air...then i have a bridge in brooklyn I would like to sell you -
now - the 930 and 950 can run at stock, at a much lower voltage then what stock is..finding if you can do that, completley stable then your oc is going to, most likely use less voltage to hit a sweet spot. If I can spend 199 on a 950 that can run 4.2 @1.2 volts and not hit 80-90 running linx for hours..on air..then yah...my 920 hit 4.2 but get far to close to 90c for me in a short run on linx and that is wtih a corsair h50 with two fans..running 1.39.
