Hey all, a friend asked me to put him together a system that will last him quite awhile. He's looking to spend $600 at most, a little lower if possible. He normally just buys store bought computers but have been able to talk him out of it, I built an i7-920 system that I sold to a mutual friend of ours and that is still going strong, what, 6 years later? with only upgrading the GPU as needed. So I was able to convince him that buying yourself a solid new foundation can last you a long time instead of recycling store bought crap every 2 or 3 years.
Browsing, gaming, videos
600
US, WI
CPU, PSU, MOBO, RAM, SSD, CASE
GPU, HD's
6) Will you be overclocking?
Possibly
1080p 60hz
this weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
no specific mobo features needed
yes windows 10
So this is the list I came up with so far PC Hound - Build a PC in Seconds
He's more of a console gamer but does play a few pc games, since he just hooks up to his 1080p 60hz tv, with the hardware today he should be able to make a system that will be able to handle most games maxed at that price range. We are going to re-use his current drives as his storage, I'm not sure size and type of drives at the moment but its enough for his storage needs. Just a 240gb SSD for boot should last him the life of the system.
I'm not sure exactly which CPU would be best to go with is the main point of the thread I suppose, then to make sure that all the other parts are as cheap as possible. I'm wondering if perhaps I should step up that CPU to the 6600k, after 2 or 3 years, oc'ing it would help prolong the life over the 6500? I'm assuming that doesn't OC well, perhaps I'm thinking wrong and that will be fine too. The video card I'm going to just sell him my extra 970 I have. We do need a list of cheap cases that people recommend that aren't crap, don't need anything special, just something cheap that will cool well and not look hideous.
Thanks for any help!
600
US, WI
GPU, HD's
Possibly
1080p 60hz
this weekend
yes windows 10
