Shadow2531
- Jun 13, 2003
(Using STL's distro)
Is there anyway to make the MS DirectX SDK work with MinGW? There's more to it than just renaming the libraries to lib<file>.a . I think the MS DirectX include files are slightly incompatible with MinGW's standard include files or more so, the lib files are incompatible.
There is a MinGW compatibile SDK at http://www.bloodshed.net/dev/packages/index.html , which works, but it doesn't have the entire lib set like the MS SDK does.
Is there a converter so I can convert the whole MS SDK or is there a more complete gcc compatible SDK?
Also, the Microsft Visuall c++ toolkit would probably work with the MS DirectX SDK, but the toolkit comes with very few of the standard include files. Where can I get the rest?
Thanks.
edit:
will reimp do the trick?
Solved
Reimp does the trick.
Thanks.
edit:
Solved
