I recently needed a RAID1 capable NAS enclosure so I went a hunting for reviews and stumbled on smallnetbuilder.com which is a killer resource for networking gear reviews.
After reading through a bunch of reviews it seemed that either a QNAP TS-209 or a Synology DS-207 were the way to go, but both cost close to $400 without drives. I found the QNAP at MWAVE.COM for $350 after rebate and was going to pull the trigger when I saw a Sans Digital enclosure with the same basic functionality as the others for $188. Searching around revealed that this is a new product, and there was NO user experiences to be found anywhere which was a bummer. Regardless, I bought it and slapped 2 WD7500AAKS sata drives I had into it. The admin web browser based app is fairly straight forward, there is a Raid Management page where I setup RAID1 and I was off and running. Besides a few rough places in the user interface (the occasional Engrish instructions(check out engrish.com for a few laughs)) it works well.
It has iTunes server capability so now my music library is remote as well as all digital pix and other data that is nice to have off of my main rig (which gets broken occasionally and needs a clean install).
As far as performance goes, it does about 8mb/sec transfer rate over a 10/100 network. I am sure if I upgraded all my gear to Gigabit (this NAS is a gigabit device) it would improve accordingly. I pulled the enclosure apart and snapped some pix as well.
Worth noting, it is a rebadged Stardom SL3620 (external product shots can be seen there) also sold by RaidSonic in Europe. Note in the picture that the motherboard is labeled SL3620. The CPU is a Storlink 3516 which is an integrated chip that has an ARM processor of unknown speed and usb/nic etc also integrated. The motherboard also has 128mb of ddr onboard. It runs a linux 2.6.xxx based OS that almost all of these type of NAS devices seem to run. It also has a little 70watt psu squeezed into what is a really small enclosure, built out of heavy gauge aluminium - very good overall build quality. It has 2 exhaust fans which are a bit on the loud side, but I located this thing in the garage. The OS is accessed via web browser like all small network appliances. It reads SMART data from the drives and in a relatively cool garage, the drives never get above 40c. Finally i pulled one drive from the RAID1 to see how it notifies you of drive/RAID failure, and despite trying to set up email and popup notifiers, my only indication was the front LED turning from blue to purple. The rebuild took about 6 hours. All in all it seems like a decent device, worth the $188.
ps. I wouldn't recommend this unit to the non tech savy, the interface is way too barebones.
