dj_spanmaster
- Aug 1, 2004
My portio.sys file is missing - not on the PC at all - and the interesting story of how I found out is below. I'd skip it. After searching the net, it looks necessary for normal port I/O operations in both Windows and Linux applications, but unavailable for download. I was wondering, do any of you have a copy of portio.sys on your XP boxes? If so, can you email me; I would like to use my shiny new toy. Thank you for your time.
Recently I purchased an RCA Lyra 2820 as a closeout from Sears. Upon hooking it up to my XP box by USB 1.1, it failed to connect correctly. Investigating the Device Manager shows "Unknown Device" under USB connections. I know that particular USB port and cable works - I've used it with my camera. I thought I was again a fool for buying a closeout (burned twice by Best Buy, once by EB) when, flippantly, I checked the "Show Hidden Devices" switch. The dreaded exclamation mark stood next to a non-Plug and Play Driver, the PortIO.sys file. And not just misplaced, but missing totally. So, as it says above, I'll probably be needing it sooner rather than later.
