what about modular video cards where you have a basic board with all the SMT resistors and caps as well as the powersupply caps. then you have the GPU in a ZIF socket. and the RAM is held in a similar system but in pairs. (Ideal use for this is the 6800 because of the amount of room on the PCB). This should allow greater flexability. it should also be cheaper in the long run.. instead of changing the whole card, just change the gpu and maybe the ram... instead of RMAing the entire unit just RMA the GPU-RAM pair... Is it possible and is it practical?
