Hi all while looking for parts for my w/c rig I had the idea that if I can I'd be beter off using one type of hose fitting wherever possible. So which kind produces the best most reliable seal?
compression
barb
or push
I personally really like the 1/4" compression fittings that are on my koolance blocks as it seems to be about impossible for them to accidently come off let alone leak.
compression
barb
or push
