At this point I'm pretty sure the motherboard is defective as I tried everything I could think of, but I would just like to get some confirmations before I go through the trouble of getting a replacement board off ebay.
This is an old socket A board with an athlon XP1800+ that was working fine until yesterday. The computer turns on, the fans spin etc, but there's no beeps or video signal either. I checked the diagnostic lights on the mobo, it indicates "The processor might be damage or not installed properly". I did the usual unplug everything, remove expansion cards, ram sticks, reset CMOS, try another video card etc but nothing helped. Then I tried another cpu, a 800mhz duron, the behaviour remained the same.
I also put a thermal probe on the bare cpu core (without heatsink) as a short test with my finger on the power button in case it shot past 50ºC quickly, but the temperature barely went above 23ºC (18ºC ambient temperature).
An interesting thing to note is that the hard drive will only power up when the ata cable is disconnected from the mobo.
I'm thinking the VRM's are defective and so the cpu isn't getting any juice and that I can just get a used board off ebay and make this system last a bit longer. Am I right on this assumption or would any of you have any reasons to suspect something else?
Thanks.
Thanks.
