What the title says, basically. I'm getting the PCI-express version. Doe it come with one of those variable-RPM fans that seem quiet at first, but quickly spool up to tornadic speeds after a minute of gaming? Or, will I never hear it in an otherwise silent computer case?
If it's noisy, what replacement HSF would you guys recommend? Nothing too fancy, maybe $30 max. Does Zalman make good VGA HSF units?
Thanks.
Thanks.
