OK, so I picked up a 1080 TI MSI Armor, and i had a 1080 FTW before the TI. On my FTW i would just set the power limit to max and then overclock +100 core +500 mem and was good to go. for the most part i dont think the FTW ever got near the temp limit of 90c.
well fast forward to the MSI Armor 1080ti. At first I did the same thing, and I was able to get up to like 130+ core and 600+ mem. Only issue is in games and stuff, it will get right up to the temp limit of 90c and go from 89/90.
Now I benchmarked like that, and got 95.4 fps in heaven benchmark at 1440p maxed w/ 8x aa.
then I set the power limit/ temp limit from 117/90 to 100/80 and sure enough it runs way cooler and fan speed stays below 100, and I get the exact same 95.4fps???? I didnt modify the overclock though, I left both runs at 100+ core and 600+ mem.
so what exactly is upping the power limit / temp limit doing, if the boost clock seems to be the same in both scenerios?
