burned-ati
- Jan 27, 2006
Hey guys here it is! A true beast of a GTX 660 OEM! This card is simply amazing!
OEM Reference MSI GTX 660 OEM, W/ Red PCB board.
Unlocked Voltage, I run it at 1,187volts no higher. Always under 65C. I unlocked the Bios, and modified it myself to run at 1,150MHz base clock from 808MHZ, and 7,160MHz memory!
The boost will not go over 1,306MHz in games, I limited it there! Minimum fan speed is set to 45%, And power limit set to 160 Watts.
I can change these upon request however you want if you buy the card. Just let me know!
The card runs flawless and looks NEW! I will post some pics when I get the chance!
NO NEED TO EVEN OVERCLOCK IT! The memory is always set to 7,160MHz. And the core pops right to 1,306 MHz in games! Perfectly stable. I have been running this card like this for a 2 months now everyday, benchmarking and heavy gaming! It is a GTX 760 Killer.
The highest in 3dmark firestrike I have gotten is 5,931 or something around there since I force updated to PCI-E 3.0 patch.
I have a Intel i7 4820K as well overclocked to 4.85GHz, Im sure I could hit over 6,000 with this card easy!
my 3820 that this was tested on, was at 4.3GHz!
I have since move to a pair of 780's and no longer need this card!
I will take $140, here is my email address- [email protected]
