I'm not clear where Edge is seeing that part number.
What are you guys getting for your OC on this board?
I simply can't find a stable enough setting beyond 2.8Ghz (1400FSB) despite upgrading case, power supply and cpu cooler (Zalman CNPS9500). Quite frustrating.
I've tried:
1500 FSB with DDR2 reduced to 667, relaxed timings
1500 FSB with unlinked default memory timings
Anything above, such as 1600 FSB wont boot. All this with +0.05v cpu, 1.3 NB and 2.15 mem. Spread spectrum is off, C1E and EIST are off. Current idle temps is 29c-32c depending on ambient room temps.
One thing that keeps popping up in event viewer, when the system freezes at higher OCs, is the i8042prt driver thats not loading. Any ideas?
I have been doing alot of research on good memory for the P6N SLI-FI aslo as I had to RMA the cheap Gskill's I got from new egg before I done my research.This ram http://www.newegg.com/Product/Product.aspx?Item=N82E16820178134 look like it works well with this board.
Thinking of one of the following:
http://www.newegg.com/Product/Product.asp?item=N82E16820150054
http://www.newegg.com/Product/Product.asp?item=N82E16820220144
http://www.newegg.com/Product/Product.asp?item=N82E16820161030
http://www.newegg.com/Product/Product.asp?item=N82E16820231065
http://www.newegg.com/Product/Product.asp?item=N82E16820609026
http://www.newegg.com/Product/Product.asp?item=N82E16820145590
http://www.newegg.com/Product/Product.asp?item=N82E16820231114
Is that the temperature values you are getting from the Core Temp program?
I wonder if the fan on my Intel heat-sink is spinning... my idle temps (at 1333) are 46-48c. I get up in the high 50's pretty fast when it's clocked up to the 3GHz range.
Yeah. Using the CoreTemp app. I must admit, I try to keep the room cool, but not cold. On a warm day, core temps idle at 42-44c. I actually got down to 35c core temp/23c cpu temp last night, although this was the limit of ambient room temp comfort for me.
Markt435, I discovered that using a side panel fan actually increased the system temps in my previous case, probably because it interrupted smooth airflow through the case, but maybe it was just the case. In the current case heat does ot linger around at all.
really? since the air is going in one straight line from intake to exhaust i don't see how it would make the temp any higher...its just weird. as long as its stable i'm ok with it. i think the ram needs the extra air more than the mobo does anyway.
it could have just been an anomaly though. i'm looking at speedfan now and the temp is back down to 28C. so i dunno.
Good advice on the BIOS Spanki. But since they are Beta? Usually hesitant on those. Anyway, I bumped up the vcore to 1.352, [email protected] and [email protected]. FSB@1500. Ran 3dMark06 twice, and passed. Its a quick and dirty stability test, but it didn't freeze, whereas previous attempts froze at the CPU test...
A working bios wouldn't hurt any, I'm tired of being stuck at 1600 FSB with my E4300. I want to drop the multi and see just how high this board will really go..........
From what I hear, if you're the adventurous type, the beta BIOS will let you drop the multi.
This ram http://www.newegg.com/Product/Produc...E16820178 134 look like it works well with this board.
I've got this ram on my FI version board & am satisfied so far. Need to make sure that you're using the right voltage in the BIOS though. I suggest 1.95v. I haven't tried to do 800mhz with it, but the reviewers say it will. Maybe some day when I'm brave enough.
Should have read this thread before I ordered.
First, thanks to all the posters for the great info here, this is the first time I've come to this forum, and this thread alone was reason enough to register and post.
Unfortunately, it sounds like I'm going to be having some issues.
Arriving today from the egg is my new p6n Platinum board, and 4 1GB of the g.skill ddr2 800 BNQ. So I have to dodge both the possibility that this ram isn't compatible, and the 4gb slowdown.
This is my gaming/photoshop box. It'll be running xp pro (I'll hold off on vista as long as possible)
It's my first SLI build (I picked up a second bfg 7950 gt oc 512 to go with the one I already have.)
Can I keep you guy posted on my trials and tribulations with this build here, or should I start a new thread?
I intend to attempt my first overclock as well, so I intend to reference the great info I've seen here. Still, I'm sure I'll have a noob question or three.
Alright,
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard
Intel e6300 C2D
2X G.SKILL 2GB F2-6400CL5D-2GBNQ (4GB total)
2X BFG Tech BFGR7950512GTOCE GeForce 7950GT 512MB GDDR3 PCI Express x16 OC
WDC WD3200KS SATA drive 300GB SATA drive 16 MB cache
Soundblaster X-Fi
Windows XP Pro
I originally picked up the processor from "Intel Retail Edge" when I worked for a computer store. It came bundled with a basic non-sli intel board and windows vista. With the new job, I was able to put aside some cash and got the new mobo, ram, and second video card.
I installed the mobo into my case (a god-awful ugly AeroCool T3), and just for grins, put all 4 sticks in. It booted right up! The only issue I'm seeing right now is that Windows is only reporting 3GB of RAM (BIOS see's all 4)
I've restarted a few times for mobo drivers and whatnot, but knock on wood, so far it looks stable.
Anyone know a fix for the 3GB instead of 4GB thing?
Excellent! As I mentioned earlier, I think 3GB is all XP is going to give you - I don't think there is a fix for that.
Just out of curiousity, do you have CPU-Z ? I'd be interested in the (various) SPD settings of that memory. Also, which BIOS version came in that new Platinum board? 1.1 ?
OK, I'm willing to sound like a total noob, cause, well, I am one. I know BIOS flashing should be done with the greatest of care. I am using the 1.0 BIOS but imagine I would want to flash to a newer version if it supports higher OCing. Latest official BIOS on Platinum is 1.1.
That said, is anyone willing to explain the step-by-step methods for flashing BIOS? I've done it for my DVD drive, but a mobo is a bit more complex . I saw some references at MSI's forum, but it still looked a bit confusing.
Specification Intel(R) Core(TM)2 CPU 6300 @ 1.86GHz
Core Speed 1599.9 MHz
Multiplier x Bus speed 6.0 x 266.7 MHz
Looks like Bios version 1?
Heh.. I'm not a noob, but it's been years since I was actively flashing BIOSes and such and even then, I've always been overly-cautious when going about it (actually, I'm not sure that you can be overly-cautious ).
I'll leave out actual instructions, but here's my thoughts on it...etc etc
Yeah, looks like they're still shipping the Platinum with 1.0 BIOS - thanks. Something odd is that it seems to be using a 6x multiplier for your E6300, which should be using a 7x multiplier, but that's probably EIST/C1E or D.O.T. going on at idle.
If you plan to do any overclocking, the first thing you'd want to do is disable all of those, along with all Spread Spectrum settings.
Ahh, cool - thanks CS.
More "help a noob" stuff - sorry!
BIOS settings - what to disable?
Specifically, what should be done with these various features:
- Boot sector virus protection (currently enabled and sounds like I want that)
- Full screen logo display (does it really matter what this is set to)
- Quick booting - (currently disabled)
- IOAPIC Function (???)
Under "CPU Feature"
- Execute Bit support (currently enabled)
- Set limit CPUID Max Val to 3
(I already did the F4 thing where I disable C1E)
Under "Chipset feature"
- HPET (???)
Cell Menu - where all the OCing takes place, or so I'm told
- System clock mode (Auto, Linked, Manual?) - currently Auto
Advanced DRAM Config
- memory timing (Auto, Manual)
running Manual, 4-4-4-15 right now with all other settings auto including Command per clock at 2T
Spread spectrum - just disable all of these???
My goal is essentially to get to 2.8gHz (400 FSB)
Thanks!
