Ugh. So I have had this MSI R9 290 for a couple weeks and I noticed over the last two days the temps would occasionally spike (go from 77 degrees C which is the normal temp at full load, to 90-94 degrees) and then drop back down. Sometimes it wouldn't drop back down and stayed at 92-94. I eventually opened the case and voila, one of the two fans on the vga cooler (the fan closer to the back of the case) was not spinning. I gave it a little nudge and it started spinning and in a few minutes temps went back to normal, but it keeps stopping. I contacted MSI and will probably be RMA-ing this but in the meantime... any suggestions? Is the fan just dead/dying?
