seniorpaul
- Aug 8, 2005
Ok, it's a long story but i've ended up with two of the new Thermochill PA120.3 rads, it sucks, i know . I was buying the first one to use in an external watercooling box, but now that i've got two to play with, i think i'm going to set up two loops. One that will cool two 7800GTX's(via slim profile Maze4's), and one that is going to cool my X24800+ and chipset (by Storm and EK-NF4 respectively).
Would i be able to have both loops using the same Resevoir? i was thinking about putting a "Y" connector after the res and one before. My two loops would then be res > "y" connector > pump > PA120.3 > Maze4 > Maze4 > "y"connector > Res AND res > "y" connector > pump > PA120.3 > Storm > EK-NF4 > "y" connector> res.
Room is quickly running out, so if i'm going to have to use a second res, i'm going to have to do some re-planning. I suppose i could also use a T-line for one of the loops. Anyway, would there be any problems if i were to run both loops from one Res?
