F
fallguy
Guest
zer0signal667 said:Do you also want the water spending more time in the waterblock to "absorb more heat"? It's a common misconception that water needs to move slowly through a radiator to be cooled well. Think of this, maybe each molecule spends less time in the radiator each time it goes through, but it goes through more times per minute - it's just going in a loop after all! It actually spends the same amount of time in there overall, so you can see how time is not an issue - fluid flow characteristics are, because that's what governs heat transfer. That's why there's such a large focus on creating turbulent flow, because it's superior to laminar flow for heat transfer properties of a system.
Go to another thread to discuss this. I dont want to hear it, Ive tested virtually every kind of setup in the past 4 years. AS I SAID EALIER, if I wanted max cooling, I would have kept my Mach II. As I said, more flow doesnt always mean better.
Now, go off topic somewhere else.
