Greetings all. I'm hoping someone here might be able to help me, since I took Eclipse advice on what RAM to get for my new system, and it seems to be giving me grief.
As you'll see in my signature, it's a DFI SLi-DR motherboard with two crucial "value" 1GB PC3200 DDR RAM sticks. At first, I had problems with getting the motherboard to boot, etc. By altering a bunch of BIOS settings to "save" defaults, per suggestions from folks at DFI Street's forums... I got the board stable enough to upgrade the BIOS. It now shows my Dual Core processor correctly at boot, and seems correct until I try to install Windows XP Media Center Edition 2005.
After booting the system from an Optical Drive in an ADS Dual Link enclosure, I'm able to start the install, format a partition on my Seagate SATA HD, and let the setup files start to copy to the HD. But at some point, the system blue screens with the following:
A problem has been detected and Windows has been shut down to prevent damage to your computer.
PFN_LIST_CORRUPT
Blah Blah Blah
Technical Information:
*** STOP: 0x0000004E (0x00000002, 0x00015BA2, 0x0007FEDF, 0x00000040)
Figuring this was a memory problem, I tried adjusting the memory from 2 - 4 - 4 - 7, to 3 - 3 - 4 - 4 - 8. I set the cmd rate from 1T to 2T, I upped the voltage to the RAM, etc. But everything I tried hasn't sloved the problem. I'm currently running MEMTEST 1.55 (since that's loaded in the BIOS), and after decreasing my memory voltage and making another tweak or two... trying to isolate what test is showing errors. I'm currently through Test 7 with none found.
You can actually see more of what I'm doing and have found here:
http://www.dfi-street.com/forum/showthread.php?p=176588#post176588
Anyone have any suggestions what the trouble could be? The one problem I see with the DFI board is there are just TOO many settings, so I don't even know what some of them are. Hopefully I'm a setting away from greatness, so I don't need to return the Crucial to New Egg and get something else.
PFN_LIST_CORRUPT
Blah Blah Blah
