I believe my DFI SLI-DR board just died. (maybe cpu, not sure) The MB shows no sign of booting. No fans turn on or anything.
I checked the PSU with a tester and it tested good so I don't think it's that. (Checked ram with spare ram too)
But I can't get the computer to boot. So I need to get my PC working on the cheap. I don't see any S939 MB's around anymore.
So it looks like my only options is a cheap AM2 or cheap Intel setup. I would need new ram since my system uses DDR. So I would need a MB, ram, cpu all for around $150.00.
My potential configuration so far is...
MSI K9NGM4-F V.2 AM2+/AM2 NVIDIA GeForce 7025 Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130162
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231144
AMD Athlon 64 X2 4400+ Brisbane 2.3GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103776
But I'm not sure what the best bang for the buck is right now. That is why I'm asking here. Can someone configure me a better setup for around the same price ?
AMD or Intel, it really doesn't matter. But the price does, I can't go past $150-$200 for these parts. I didn't list anything Intel because I'm not familiar with the Intel side. If you can show me a better performing or a more OC freindly system for around the same price. That would be awesome.
Thanks
Thanks
