phildabill
- Jan 9, 2007
Hello,
After breaking my good old logitech mx700 three months ago, I decided to give Razer a try. I bought a Deathadder as I always liked a big mouse, and I directly loved it… extremely comfortable, fast and precise.I decided to order the Mamba since I loved the Deathadder but hated the cord.
This is a quick review/rant of my problems with the mouse. Note that if it worked properly, it would easily be the greatest mouse ever made. I am running on XP64bits, and updated the firmware from an XP32 machine (64 is not supported yet):
Little rant on the packaging: it is a mouse….not a trophy. It is completely useless (the old cardboard box was fine). While this should not be of any importance, it definitely plays a role in the price of the mouse. Shipping would have also been cheaper. Living in Montreal Canada, I paid 30$ US for the shipping from Olean, NY (400 miles)…
I am curious to know if I am the only one experiencing these problems. Seeing how the mouse was released 1 month ago and there aren’t complaints, I hope my case is unique. Else it is completely unacceptable to release a product like this.
If you own a Mamba, please post whether or not you are experiencing these or other problems.
Regards,
Phil
UPDATE:: Haven't been able to fix the bug on mine since it woke up this morning....Tried it on a 32 bit system, got the same problem....Video Link: http://www.youtube.com/watch?v=TG7SNqrNDMg
UPDATE:: The problem has become a lot more sporadic, but still occurs. Stopped using the mouse as it was driving me nuts. Awaiting confirmation from razer to replace the mouse.
UPDATE:: Started using the mouse again with the new driver...still have most of the issues. Noticed wireless starts bugging according to battery level (mine still doesn't charge to full). Maybe its lacking the power to emit and the indicator is NOT reliable.
UPDATE:: Razer is sending me a new mouse. Thankfully I don't have to pay for shipping, as it would easlily cost 40$CAN to send it from Montreal to California.
UPDATE:: Asked for a full refund as replacement had issues...
UPDATE:: Tried the new beta 1.05 firmware. Mouse still locks up I/O, except this time if I am pressing a key on keyboard it acts as if I was holding it. Still does not charge on dock with mouse turned ON (on both, original+replacement)...
UPDATE:: After letting it sit and charge on another computer for a few days. The mouse now seems to be working perfectly fine. Only problem is going from wired->wireless, clicking takes a good 20 secs to work. Removed my conclusion as I *could* be wrong
UPDATE:: check my last post.
- Going from wired to wireless is NOT seamless. In my case, every time I do the swap, the cursor of the mouse does not work (buttons do though). I have to turn the mouse OFF/ON to reinitialize it. Since I turn it off, the polling frequency resets to 500hz and has to be changed back to 1000hz (check 4-5).
- Sleep mode. Every time my mouse goes into sleep mode for a certain period of time, it does not resume properly. This was supposedly addressed in the firmware update, and I can confirm that it was tampered with as the results are different now…
Before the update, the mouse would look as if it were working (battery lights on, changing profiles via mouse buttons worked), but the mouse itself did not work (cursor and buttons). I would have to turn ON/OFF the mouse to wake it up (and reset polling rate).
After the firmware update, it can now sometimes work, but there are still chances it will bug. I have seen 3 scenarios up to now:
- Same as pre-update.
- The buttons work but not the cursor (going wired/wireless fixed the problem).
- The cursor locks up every 10 seconds (wired/wireless does NOT work, I am currently stuck with this!)
- Waking up the mouse takes up to 8 seconds (when it works)! You are reading this right…up to 8 seconds. 8 seconds of staring at your computer screen for the cursor to become active (buttons work though). It does seem however that the mouse has more than 1 sleeping stage, as if you stop using the mouse for 2-3 min, waking it up takes 1 second. Apparently this is normal behavious and “Moving it around your mouse pad usually helps speed up the wake-up process.” (From one of their tech support replies)
- The Mamba configurator must read the on-board memory of the mouse every time it is opened. In wired mode this takes 3-4 seconds. In wireless however, this takes at least 10 seconds. Writing the firmware via wireless takes longer, and occurs when you click APPLY and OK. This means that every time you make a change, the firmware is written 2 times, once upon pressing ‘apply’, and once upon pressing ‘ok’ to close the application.
- The Mamba configurator locks up ALL INPUT DEVICES for a few seconds when reading/writing the firmware (Only sais the mouse so in the popup). In my case it locks my PS2 keyboard and my Deathadder (plugged when I was comparing the 2). Therefore it is not only limited to USB. Seeing how it locks I/O for a few seconds, I do not think it would be a good idea to open the configurator while performing I/O on external devices (ie: transferring data to a USB drive).
- On my specific mouse, the 6th button (default Sensitivity stage up) is hard to press. While this is a problem, a simple RMA would fix it. No need to elaborate on that. Manufacturing errors occur…
- On my specific mouse, even when the battery is fully charged, the power bars only light up 2/3 bars.
Regards,
Phil
