Makaveli@BETA
- Mar 24, 2004
Hi everyone, i'm just about to replace my aging Opteron 170 system that has served me so well for the past couple of years. And i'm going to building a i7 rig my first build on the darkside since the pentium II.
After looking at my options I've decided to go the X58 route over lynnfield. I'm looking for any suggestion on my component selections and I plan to post some pictures as soon as I start the build.
Intel Core i7 920 D0
Asus P6T Deluxe V2 Socket 1366
OCZ DDR3 PC3-12800 1600MHz Platinum XTC 6GB
Noctua NH-U12P SE2 or TRUE Revision C or Megahalems.
This upgrade will cost me $1000 roughly, I will be using my previous tower, drives 640WD for boot and 2x 750WD storage and a Enermax Infinity 720Watts.
I did price together to lynnfield system just incase.
Intel Core i7 860
MSI P55-GD80 Socket 1156
OCZ DDR3 PC3-12800 1600MHz Platinum Edition Low Voltage 4GB
roughly $900 so the difference in price was so small that I decided to go the X58 route.
I previously upgraded my 3870 to a 4890 so already have this for the build. I just need to transfer my S1 Rev 2 onto the new card.
The one question I do have is my x58 motherboard choice. What is the feedback on this board? I decided on this one because the price was good, I don't intend on speeding 400-500 on a motherboard which most of the top end X58 ones currently retail for.
I did also put together an AMD system but the gap in price wasn't large enough for the peformance I would be giving up.
AMD Phenom II X4 955 Black Edition
MSI 790FX-GD70 ATX AM3
Noctua NH-U12P SE2
Around $700.
O also most forget I will be throwing a SSD in the rig sometime in the january timeframe I believe.
Intel Core i7 860
Noctua NH-U12P SE2
Around $700.
