I think this X-Mas I am going to put together a HTPC build. It only needs to play Netflix, maybe Hulu, DVD and Blu-Ray rips from the file server. It will be hooked up to a Panasonic 54" Plasma. The front end will run XBMC. I went with an SSD because I want it to run quieter and cooler than a standard HD.
Memory: 4GB G.Skill DDR3 $49.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
Mobo: ASRock H55M Pro $89.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16813157181
CPU: i3-530 $99.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16819115222
Case: APEX Micro ATX Slim $39.99 http://www.newegg.com/Product/Product.aspx?Item=N82E16811154087
PowerSupply: SeaSonic SS-300TFX $37.99 + $8.26 shipped http://www.newegg.com/Product/Product.aspx?Item=N82E16817151090
OS+SSD Combo: Win7 Pro and OCZ Vertex 2 60GB SSD $209.98 http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.544791.20-227-550
Blu-Ray: $79.99 LG http://www.newegg.com/Product/Product.aspx?Item=N82E16827136183
Thoughts and suggestions?
