stumpy said:Cookie, watch out for that tube going to the video card, looks a little tight...just be sure it doesn't crimp on itself.
Just a heads up.
Big or small one?gclg2000 said:where did you get that lcd?
compugeeks?
Thanks for the heads up, adding extra Coolsleeving to that section just incase.Stumpy said:Cookie, watch out for that tube going to the video card, looks a little tight...just be sure it doesn't crimp on itself.
Just a heads up.
Hehe , on it, but the pic makes it look worse than it actually is. But I wonder if a flatter tube with no kinks makes flow worse than an rounded tube.RickyJ said:I just noticed that too. Pull that Coolsleeve down, and it should help.
CookiePuss said:But I wonder if a flatter tube with no kinks makes flow worse than an rounded tube.
RickyJ said:Try drinking through a straw and pinch the straw. The straw keeps the exact same circumference, but the cross sectional area inside decreases. This is the same with tubing. A flat tube is almost a kink, since the sides are pushed out (decreasing height, which decreases the x-sectional area). Thus, a flattened tube is worse than a rounded tube.
Aftermarket exhausts fight this with the bends. You can either bend it, crimp bend it, or mandrel bend it. The smoother and rounder you can keep the pipe, the more it will flow. Same with any tubing.
weapon-- said:by "near ambient temps" are you referring to the temp of the coolant?
anyway, brief pic barrage from the weapon created core collection:
before the shroud:
shrouded
ardawg's core mounted in his slightly oversized case (his case is a Sun Mass Storage Unit )
nbd's 6x6 core with flat side panels:
^that pic does not do that core any justice -- it turned out schweet.
