nigerian_businessman
- Sep 3, 2004
So I decided to give it a real try since my stepdad unknowingly bought a copy thinking it would run on their computer which is a bit dated.
Now, I'm not going to universally slam it here. There are things I love about it. The interface update is nice. I like the new start menu (with 1 caveat, I'll get to that later). I like that I don't need separate software for my Windows Mobile 5 Smartphone anymore, especially considering the clusterfuck that was activesync on XP. I'm a huge fan of built-in drive encryption, even if there are other solutions out there for XP, having it available on the fly is nice. Not all of the 'usability' improvements are actually bad, although for now most of them just get in my way.
However, I'm still of the mindset that this OS really doesn't offer much as far as an 'upgrade' goes. Heres why:
Since I must be some kind of masochist, I will probably keep it installed and just figure out ways to disable and remove most of the shit I don't like, since I'm sure there's some way around most of this crap. My rating? Nice OS if you don't have to pay for it. Otherwise, avoid.
- File & Disk Permissions hell. I have a lot of disks and partitions, and the new security measures consistantly stand in my way of doing simple tasks with no clear workaround. For instance, I tried to import my photo album from F:\My Pictures into the Windows Photo Gallery. I was confronted with an error stating that the folder, or its parent, were set as either a system folder or hidden and that the operation couldn't be completed. I searched through the properties to find out how to change the flags (an incredibly simple thing to do on linux, but thats another story) with no luck whatsoever. I attempted to change ownership of the whole drive from the Admin group to myself. Didn't help. Windows suggestion in the error was to copy the folder to my Pictures folder on the system drive. Nevermind that the folder is 30gb and perfectly fine right where it is. Also, I attempted to remove a partition in the Computer Management console. Attempted, because there is no way for me to do this. I attemtped to change ownership and all that happy horseshit. None of it made a difference. The option to delete the partition is greyed out. I guess I will have to once again switch over to Linux to actually do something I want to do with my computer.
- Random unexplainable slowdowns - Now, my main desktop is no screamer by any standard. Single core A64 3200+, 1gb ram, X800Pro video, mix of various PATA and SATA drives. Still, I got an experience score of 4.2, which isn't too bad considering the max is 5.9, and puts this computer in the higher-mid-range of systems. So why is it that when I want to navigate into folders in the Start menu, my computer will at times freeze for up to 30 seconds. I'm trying to chalk this up to the indexing service and this being a new installation or something, but really I don't know where this slowdown is coming from. I'm not doing anything intense, just trying to browse the start menu. The start menu on my previous Windows XP install had scroll buttons at the bottom and top from all the programs I had installed and it was snappier than the start menu on a nearly fresh install of Vista. Go figure.
- Usability improvements - I said not all of them. But most of them I could do without. Renaming stuff for the sake of change does very little in terms of actually increasing productivity. In fact, considering Windows is pretty standard, it really only makes people familiar with it (pretty much everyone) scratch their heads and go WTF? Where is... The control panel is once again dumbed down to the point of being complex. It's like the people who designed it decided too many choices are intimidating, so instead of presenting them all at once, we'll make it so you need a fucking tomtom to navigate our maze of vague selections. Changing around Windows Explorer once again without presenting any easy way of getting back to the classic way of doing things was also a big fuckup on their part. Where the fuck is my File Edit View etc menu? Was there something wrong with over 10 years of conventional usability that it needed to be tossed out?
- UAC Prompts - I don't care what anyone says about "increasing security". This is god damn rediculous. Downloading and extracting a zip file full of png icons for rocketdock into the \Program Files\Rocketdock\icons\ folder took nothing short of 4 approvals for ONE zip file. I had to do this over and over and over again to get my dock icons installed. Never was I presented with any simple way to turn the notifications off or give permission to do the same type of task for a short while. Turning off UAC for 15 minutes so I could actually get some fucking work done isn't an option either, since that requires a reboot. So, once I reboot, UAC is going off. I'll take my chances, kthxbye.
